As already stated an aggregator is included in Log4om version 2hb9ajy wrote: 02 May 2019, 13:45 Is there any progress for this subject at Log4OM? Would very much appreciate this feature.
Thanks 73
Fritz HB9AJY
Spots for SmartSDR
Re: Spots for SmartSDR
actual version 1.36.0.0? When can version 2 be expected?
Tell me version 2 is already available?
If this is working since January, where are the instructions to get the spots collected to be displayed within the pan adapter within SmartSDR? I've check the docs, tried to follow directions, but still don't have any spots within the pan adapter. If the aggregator is the solution, is it writing the output in the format that SmartSDR is expecting?
The question was about the availability of Log4OM version 2 which was released in January 2020
Thank you Terry. Are there any updates to this topic? Or better said, where is this topic on the roadmap for completion?
NG7E wrote: 21 Jul 2020, 15:58 Thank you Terry. Are there any updates to this topic? Or better said, where is this topic on the roadmap for completion?
We provide a cluster server which rebroadcasts spots aggregated from out Telnet facility, did you try that with the Flex? cant see why it would not work assuming Flex software can handle it.
I believe i did try that but nothing showed up. I also believe that the flex API has certain requirements not just what comes out from a Telnet cluster in a specific format.
