Integration with DM780
IU2GZZ
Post by IU2GZZ »
I tried to create an UDP connection (port 2237) between LOG4OM and DM780 but apparently is not working.
Any suggestion? Thanks in advance
IU2GZZ
Re: Integration with DM780
Long time ago that i worked with Log4OM V1 and DM780 integration but ...
1. Have you set the UDP Port to the same Port number in Log4OM communicator (Inbound) and in DM780 settings ?
2. Did you start DM780 first with it´s own CAT control by HRD ?
Rick Rhule at HRD LLC crippled that possibility in DM780 because he objected to our integration, its never worked since.
