PHP website code to connect MySQL database
pa2eon
Post by pa2eon » 24 Jul 2017, 08:43
Dear OM's,
Log4OM can connect to a MySQL database.
This database you can make active on your own website server.
== Does anyone made a small php script to connect directly to the MySQL database of Log4OM to handle the QSO's direct in the MySQL server. ==
This means that when you are on ex. /P location .. you don't need to use the Log4OM program on your computer is you are not at home .. or you are outside your home-QTH to change or log an QSO.
If you are at home again.. you can handle the filled in records again in Log4OM.
vy '73
Eric
