Integration Logs of WSJ’s-x 1.8, Jtalert into log4om
DK6KM
Post by DK6KM »
Hello dear Admins,
i need help. I can’t integrate my jtalert logfiles from wsjt-x Version 1.8 into log4om. I have done what is written in manual page 164 but no result.
Could you help?
73 de DK6KM
DK6KM
Re: Integration Logs of WSJ’s-x 1.8, Jtalert into log4om
Post by DK6KM »
I am not sure which udp Port I must choose, 2236 or 2237?
Also I am not sure if it works to connect fldigi and wsjtx with log4om at the same time. This is what I am doing all the time. Or I must open two times the connector with different settings?
Or I must use vspe splitter?
I am using (opened) omnirig and cat with fldigi and wsjtx at the same time two.
Hope you can help me.
No splitter ... Use Log4OM with Omnirig. Set WSJT-X to Omnirig. Start Log4OM as the first instance and
WSJT-X after this. Configure JTAlert to log direct to your L4O sqlite file. Port 2236 will be o.k.
If you have some other problems send a mail to me and i will try to check out your problems..
Mailadress is my call via darc.de
DK6KM
Post by DK6KM »
HALLo, das geht dann ja auch auf deutsch.
Nutze ja omnirig, aber habe fldigi und wsjtx gleichzeitig laufen. Muss ja dann im communicator auch 2 unterschiedliche polling Dateien angeben für die beiden logfiles oder?
DK6KM
Post by DK6KM »
Habe es eigentlich genauso genacht aber irgendwie will es nicht so.
Muss ja vom fldigi und vom wsjtx bzw. Jtalert den logpfad für polling angeben, so hab ich es mal verstanden.
Better we talk in english if we´re talking here .. WSJT-X and also JTDX working fine if you use
"Omnirig" in the WSJT-X/JTDX Transceicer setup. Logging to L4O also fine if you use JTalert. You may start L4O first and then the other
softwares on the next step. FLdigi needs XML RCP activated in Log4OM Settings and in Inbound settings of the Log4OM communicator ...
So please check the Manual or take a look on Terry´s nice Youtube
files ..
DK6KM
Post by DK6KM »
OK. Thanks. I will take a look on terry‘s videos. The manual I have read and it doesn’t work, so I must find the mistake. I think it is a little thing.
73 de DK6KM
Hello OM,
would be nice to see your Name in a signature or under a sendet email. It´s easier to talk togehter
when we can use the real Name, HI
B.t.w. thank´s for your email but i will answering here so that other guys which have the same problem
can find some needed answeres.
First of all, it´s much better to log to Log4OM via the nice APP JTalert. It has logging to log4OM implemented
and you need only the path to Log4OM´s SQLite file in JTAlert, it writes directly to the SQLite database and
there is no log polling needed. Please check out hamapps.com for more info about JTAlert.
B.t.w, if you are using Omnirig for CAT in Log4OM set your Radio in WSJT-X (also in JTDX) to Omririg and you
will have CAT funktions from both softwares. That´s working fine for me.
No idea at the moment how it works if Fldigi is running together with L4O and WSJT-X but in
FLDigi must CAT via XMLRPC enabled and in the communicator inbound setting must it be enabled too.
I will do some test in the next 2 days to find out all 3 can work together at the same time and i will
report this here in the thread ...
So please stay tuned ;) 8-)
I have tested a bit with the actual Fldigi 4.0.12 and all programs workin fine
together ....
First read the manua starting on Page 186 (Fldigi integration) and do all the
settings in Fldigi and in Log4OM communicator as described ... In Fldigi
Setup klick on "Initialize Button" before you close both programs.
Startup:
First start Fldigi followed by Log4OM, both softwares display the same QRG.
Now you can start WSJT-X followed by JTalert (we prefer logging with JTAlert).
Note: This is working only if you use Omnirig for CAT in Log4OM and if you set
your Radio settings in WSJT-X or JTDX to Omnrigi1 or 2 (if Log4OM is connected
to Rig 1 you have to use Omnirig 1).
ADIF polling is not needed ;) ;)
Hope this helps you and all the other guys like doing the same ....
