FlDIGI and TS-2000
wd0dxd
FlDIGI and TS-2000
Post by wd0dxd »
Hi all,
Moving over from HRD. I have log40m, omnirig and WSJT-X working great. Really like the interface.
However, I can not get FLDIGI to work. I have it setup to use xml-rpc, I get green in the commander window on all three lights and when I try to transmit, PTT is keyed, but no sound.
I know this is due to RST needing to be set high, other wise the TS-2000 gets it's sound from the mic, not acc2. In WSJT-X I just set the PTT Method to RTS and the Port to CAT. I am unable to find a similar solution in FLDIGI.
Am I missing something? I would like to get it working, then the functionality would be the same as HRD.
Thanks for the great software any any help you can give me.
WD0DXD
Re: FlDIGI and TS-2000
Did you install Omnirig, Log4om, WSJT and FLDigi to 'Run as an administrator as detailed on Page 1 of the Log4OM quick start guide, Page 9 of the user guide and in the YouTube tutorials?
wd0dxd
Post by wd0dxd »
Yes, I did that.
WSJT-X works fine. It is just FLDIGI. It will key up the PTT, but the input is coming from the mic not ACC2. WSJT-X allows you to enable PTT using RTS. Which on the Kenwood, enables input from ACC2. Anyway, that's what my research leads to so far.
Allen
WD0DXD
wd0dxd
Post by wd0dxd »
I Don't know if this will help, but this is a shot of the WSJT-X set up:
Show me the soundcard and rig configuration screens from fldigi
wd0dxd
Post by wd0dxd »
The attachment Capture2.PNG is no longer available
wd0dxd
Post by wd0dxd »
wd0dxd
Post by wd0dxd »
wd0dxd
Post by wd0dxd »
Let me know if you need anything else.
Allen
WD0DXD
What interface are you using to the ACC socket?
