Integration with JS8Call?
Posted: 12 May 2019, 12:39
by WoWKO
Hello:
I'm wondering if there are any plans to integrate Log4OM with the relatively new JS8Call, a derivative of WSJT-X. I'm currently manually importing ADIF files from JS8Call into Log4OM, which works of course, but more automation of logging from JS8Call would be wonderful.
Is this possibly in the time horizon for a future release?
Thanks, and 73,
Rob, W0WKO
Re: Integration with JS8Call?
Posted: 14 May 2019, 08:29
The inbound UDP service is already in Log4om and JTalert already uses it to write in real time to the Log4om logbook
It's up to the author of JS8call to make the integration work as Laurie did with Bakery, I suggest that you make a request to the JS8call group or author
Posted: 14 May 2019, 09:31
by WoWKO
Thanks, Terry. After posting this topic, I realized that I hadn't asked the JS8Call developer the same question, so I did so. I haven't yet had a response.
Thanks again, and 73,
Rob, W0WKO
Posted: 17 May 2019, 23:40
by G4DWV - Guy
The developer's reply was to use the JS8Call API as it does not use the UDP parts of WSJT-X.
