There is a way to have Log4OM and DM780 (Swiss made version) working all together, where log4om reads frequencies and other informations from Omnirig with a custom HRD.ini rig type definition to be used to drive Ham radio Deluxe 3rd party serial port via Omni-Rig.
IW1AWH wrote a great document on how to do that, that worth a read:
http://iw1awh.jimdo.com/doc/
Integrating DM780
Integrating DM780
Re: Integrating DM780
I am using the latest version (1.16) and and trying to get DM780 to talk to Log4OM. I read your document, however, my screen is missing the "Inbound connections for log" section which has the "UDP Connection (DM780)" check box, therefore I see no way to enable this integration following the instructions in the document. Is there a new way of doing this?
Michael,
You need to click on the actual word "Inbound" for the window to open, it is not a fly out like the "FLDigi Interface" selection.
Don't forget that the communicator must be stopped before you can change the inbound settings and then restarted afterwards
- Untitled.jpg (35.84 KiB) Viewed 12472 times
Thank you for the quick reply, that did the trick. May I suggest that that functionality be exposed as another pop-out menu? The current behavior is very unintuitive and almost impossible to discover without outside guidance.
Thank you for the reply. You have a fantastic program! One thing that impressed me the most if the quality of the User's Manual, something that most programs are lacking. Keep up the good work!
Full merits and credits for the user manual goes to Terry G4POP, that is providing the best "customer service" i can imagine for Log4OM.
Data quality and our best lookups are provided also with the work of other team members, mainly K7PT Chuck, that is mantaining our Special Callsigns file and the country file with the most up-to-date rules for callsign recognization.
The last, but not least, is our users network, that suggests, tests and help us make the toy as you can see today
I made the software, but everything else is made by the team that works behind the scenes with me.
Without this teamwork we're only another software in the list.
Daniele
Daniele
In that case, you have a great team and a great piece of software!
hi there
i intergreted dm780 with log4om, just want to know if there is a way to do it without have hrd and the log running, is it possible to work with only dm780 and log4om open?
reguards soren / oz0jx
Yes this is detailed in our user guide and of course we have full integration with Fldigi
