Cluster-Filter "Phone" vs "FT8"
oe3ide
Post by oe3ide »
would be fine for version 2.0 if FT8 & JT65 Spots (..74 & ..76) would be excluded on cluster filter "Phone" :-)
73 de Ernst
OE3IDE
http://www.oe3ide.com
Re: Cluster-Filter "Phone" vs "FT8"
Edit your bandplan to list the agreed FT8 and JT65 frequencies as DATA then activating the Phone filter will exclude them
You will of course then miss any phone operator that is transmitting on the agreed data frequencies
oe3ide
Post by oe3ide »
Terry, thank you very much :-)
73 de Ernst
oe3ide
Post by oe3ide »
it doesn't work for me.. maybe I missed something:
7074 should be recognized as "DIGITAL". See my bandplan.xml:
Code: Select all
  <BandPlanRange>
    <Band>40m</Band>
    <Start>7000</Start>
    <End>7030</End>
    <BandUpperLimit>false</BandUpperLimit>
    <EmissionType>CW</EmissionType>
  </BandPlanRange>
  <BandPlanRange>
    <Band>40m</Band>
    <Start>7030</Start>
    <End>7040</End>
    <EmissionType>DIGITAL</EmissionType>
  </BandPlanRange>
  <BandPlanRange>
    <Band>40m</Band>
    <Start>7040</Start>
    <End>7073</End>
  </BandPlanRange>
  <BandPlanRange>
    <Band>40m</Band>
    <Start>7073</Start>
    <End>7076</End>
  </BandPlanRange>
  <BandPlanRange>
    <Band>40m</Band>
    <Start>7077</Start>
    <End>7300</End>
    <BandUpperLimit>true</BandUpperLimit>
    <EmissionType>PHONE</EmissionType>
    <ModulationType>LSB</ModulationType>
  </BandPlanRange>
Thanks for help :-)
73 Ernst, OE3IDE
PE5TT
Post by PE5TT »
Why do you define DIGITAL 3 times ?
From 7030 to 7040, from 7040 to 7073 and from 7073 to 7076 !
Why not like this:
Code: Select all
<BandPlanRange>
    <Band>40m</Band>
    <Start>7000</Start>
    <End>7030</End>
  </BandPlanRange>
<BandPlanRange>
    <Band>40m</Band>
    <Start>7030</Start>
    <End>7077</End>
  </BandPlanRange>
<BandPlanRange>
    <Band>40m</Band>
    <Start>7077</Start>
    <End>7300</End>
  </BandPlanRange>
ps. i also changed 7076 to 7077 to create a gap less maping
oe3ide
Post by oe3ide »
i tried it with your cleaned 40m bandplan (bandplan_r3.xml)
Code: Select all
  <BandPlanRange>
    <Band>40m</Band>
    <Start>7000</Start>
    <End>7030</End>
  </BandPlanRange>
<BandPlanRange>
    <Band>40m</Band>
    <Start>7030</Start>
    <End>7077</End>
  </BandPlanRange>
<BandPlanRange>
    <Band>40m</Band>
    <Start>7077</Start>
    <End>7300</End>
  </BandPlanRange>
But obviously it does'nt work for me as expected ...
Thanks & 73
Ernst
PE5TT
Post by PE5TT »
I don't know how it al is configured in Log4OM , it just seemt strange to me to define DATA 3 times.
And now i think that bandplan_r3.xml is for region 3, We in western europe live in region 1, so to me it seems you have to change bandplan_r1.xml
But again i am not a Log4OM expert.
PG8M wrote: 28 Jul 2018, 10:27And now i think that bandplan_r3.xml is for region 3, We in western europe live in region 1, so to me it seems you have to change bandplan_r1.xm
Correct! Assuming the user enters the correct call sign, country and region in the Options\station info menu, when Log4om is opened it will use the regional bandplan for the region entered in the Station info tab.
Changing the region 3 bandplan will achieve nothing if your in another region unless you rename it to include _user.xml then Log4om will user this user defined file
oe3ide
Post by oe3ide »
Mea culpa!
I thought R1, R2, R3 are release versions ....
Will test it now with correct bandplan for region 1.
Thanks for quick help!!
73 de Ernst
OE3IDE
