IW3HMH wrote:Hi Kurt,
we are working on some parts of the code, and labels are on the list. There are a LOT of requests, as you can imagine, so i'm concentrating on some of them.
Label Printing is under a "private Alpha stage" where i'm defining a small Scripting Language to work on labels, but it's a big work keeping it simple...
Thanks Daniele for your reply,
well, to keep it simple, why not using the way I once proposed (to have a simple file, xml or even txt, containing the x and y coordinates of each field..). Usually a label layout will not be changed every day, so no reason to have a big graphical designer.
I understand that it's a lot of work, but I'm still convinced that it would be a big step forward for your already built-in label printing tool.
73s and thanks
Kurt HB9XCL
