Hi ALL
Please can I add a feature suggestion.
Can we have the tune button also on the Macro Screen. If you change bands you need to keep swapping screens to tune.
I would also prefer a large start button rather than hide WinKeyer in the Radio menu.
Regards
Martin - G6VMR
WinKeyer Feature Suggestion
Re: WinKeyer Feature Suggestion
Thank you this is perfect in 1.23.
Martin
Martin
Martin, are you using Winkey USB?G6VMR wrote:Thank you this is perfect in 1.23.
Martin
My RS232 Winkey doesn't work with v1.23 and appears to be a known issue.
73 Dave
Dave,
I did respond in your other thread that we are working on this with the guys at K1EL and that I have sent Lele an old serial Winkeyer to test with!
Yes it has been outstanding for a long time but it's not the only thing we have to work on and of course Lele does the coding in his spare time while doing a full time job and raising a family
Sorry for the inconvenience but I am sure we will fix it eventually
I use WinKeyer USB (The SMT version)
It works really well with all versions including 1.23
The only issue I have ever had and still have is around the speed pot numbers sometimes fall outside of the upper and lower setting in the application. Wind the pot to full then minimum normally sorts this out until the next log off and on.
Martin
Martin
