Thanks again to the development team for its latest v1.23 iteration.
I particularly like the VFO A and VFO B TX and RX notations.
However, I wondered if there should not be both a RX and TX notation on the active VFO, and just a RX notation on the inactive VFO, in the case of a dual watch or dual receive radio?
I have also noticed that the status is only interpreted once upon opening the log-book, and does not change its status during that session, even if I should operate in Split mode, or exchange VFO's.
Also wondered about the ability in the next iteration to have the VFO adjust to frequency, when using the Cluster spotter field to activate the log QSO function. (double click an entry in the Cluster spot field to the QSO window, and active VFO follows)
I am using the Yaesu FT 2000 with the Omnirig interface for Log4OM.
Regards,
Kumar J85K
Log4OM V1.23
Re: Log4OM V1.23
Double click actually does the frequency change... I am missing something?
