Cluster Heartbeat setting
Posted: 06 Mar 2016, 16:38
by VA3KA
I am having ongoing issues with my Telnet connection to DXclusters timing out after 3-4 minutes when there is low activity.
This does not appear to be a Log4OM issue but something to do with my Internet provider. I have been in preliminary discussions with them and they are so far not able to determine the issue (they claim it is from a downstream provider).
Would it be possible to have the heartbeat timer modifiable in the future. I was able to do this in my previous logging s/w (Win-EQF) through a configuration file edit.
Thanks and 73,
Ken VA3KA
Re: Cluster Heartbeat setting
Posted: 07 Mar 2016, 17:46
actually it's set to 240 seconds (4 minutes)
do you need a more frequent HB?
Posted: 07 Mar 2016, 23:04
by VA3KA
Until the issue is resolved I probably need a 60 second heartbeat!
Thanks for the consideration.
Ken VA3KA
Posted: 22 Mar 2016, 19:29
A lot of cluster managers will hate me...
Posted: 22 Mar 2016, 21:04
by VA3KA
I won't reveal my logging program!!
I really only use one "local" dxcluster in any case (and a 2nd as a back up).
As there are sometimes 3-4 spots a minute, I don't imagine my 1 keepalive a minute will cause much of an issue.
My Internet provider still has not found out why my telnet sessions are timing out after 3 or so minutes. I will try again to get them to try to solve the issue.
Is there any way to make the keepalive timer user controllable?
Also, I am not clear on what the "Timeout" function on the Cluster page does.
Thanks and 73,
Ken VA3KA
Posted: 30 Mar 2016, 14:54
Hi Ken, i'll check if i can add something in the next one
Posted: 31 Mar 2016, 20:51
Added in 1.25
It's not a "visible" parameter. You should manually edit the LogOmUI.exe.config file searching for ClusterHeartbeat tag into xml.
Recommended is 240
Anything less than 30 will be reset to 30 seconds at runtime.
Posted: 31 Mar 2016, 21:46
by VA3KA
Great news thanks for the effort. I still have not got resolution from my Internet provider.
When do you anticipate 1.25 will be available?
Thanks and 73
Ken VA3KA
Posted: 10 Apr 2016, 18:29
i'm building Release Candidate 1
