Lg ID
Posted: 20 Mar 2018, 14:05
Hi
I know that the name of the Database that has been loaded appears at the bottom right hand corner of the window, but it quite small and I have 6 different callsigns and therefore 6 separate logs. It can cause problems if I boot up Log40M with the 'wrong' Database loaded and start logging contacts!
It would be very helpful if the name of the Database in use could be made more obvious. Perhaps it could appear in the top icon band somewhere to the right of the Rig selection option and in letters similar to the PTT?
Even I should be able to spot that!
