SmartSDR v2.3 for Windowsintroduces a feature that allows Spots, supplied by third party programs, to be displayed directly in the Panadapter window. Some of these programs include N1MM, FRStack, Slicemaster, DXLabs, and Logger32. While there is no capability in SmartSDR to directly connect to a cluster server via telnet today, spots can be provided using these programs as well as any other third party program that uses the new Spot API commands in the radio.
It would be awesome if Log4OM could join the above programs in supporting the this feature.
The following is a link to the SmartSDR spot API:
http://www.flexradio.com/flexlib/class_ ... _spot.html
The following document explains the various Spot controls that are available in SmartSDR:
http://www.flexradio.com/downloads/spot ... ption-pdf/
Integrate with the new SmartSDR Spots feature
Re: Integrate with the new SmartSDR Spots feature
A search revealed that this feature has already been requested and responded to in this thread viewtopic.php?f=10&t=3473
I'm checking API released... maybe something basic is possible
Hi all
Any news on this development ?
I saw some messages that were about 2 years old, but nothing since.
Is this available yet, or will it be in an upcoming update ?
Thanks + 73
Paul F6EXV
Paul F6EXV
Paul you are using Log4OM V2 and this question was asked for the old V1 version
of Log4OM.
A search for SmartSDR in the V2 part of the forum will show you this results:
search.php?keywords=SmartSDR&terms=all& ... mit=Search
of Log4OM.
Juergen
None of these topics answers my question... Is it possible to have the spots displayed on the SamrtSDR Screen from Log4OM ?
Something like this ? (see attached)
The example shows spots received from DXLog (contest program). Is it possible to get the same from the spots from the cluster that Log4OM is connected to, say for daily operation.
- spots.jpg (110.45 KiB) Viewed 14359 times
Thanks + 73
Paul F6EXV
Paul F6EXV
I know that but this is the wrong place for your question. Your´s is related to V2 and we
are here in the V1 section. By the way, i don´t use a Flex or it´s SmartSDR software so
i don´t have any idea.
