Incorrect Spotting
Posted: 13 Jul 2019, 19:45
by w9mdb
Noticed when spotting FT8 that Log4OM is using the "standard" frequencies which seem out of date or, at least, incorrect.
Seems like spotting should ask for the mode and not assume CW, Digital or Phone and have the user choose.
de Mike W9MDB
Re: Incorrect Spotting
Posted: 19 Jul 2019, 06:25
by NN7D
w9mdb wrote: ↑13 Jul 2019, 19:45
Hi Mike,
i take it that you are referring to reported FT8 spots? Those frequencies reported come from the Skimmers involved, and likely being reported by JTAlert using Hamspots.net or WSJTx via PSKReporter. Its the freq which CAT control is set in WSJTx. Yeah, not the actual freq where the DX is located in the FT-8 band. But do we really care, as you just need to know the place to set the radio, then you will decode the dx when received?
Now are you referring to sending spots? Or FT8 spots received, and the always inaccurate mode of Phone or Digital for the spots? If the later, wait until version 2. Big changes - the actual mode of FT8 or FT4 will be shown and reflected in log4om as you log. Yeah!!!
I hope this helps,
Doug - W7DRM
Posted: 19 Jul 2019, 16:53
by w9mdb
Sending spots...so tapping my toe waiting for version 2
Mike
Posted: 19 Jul 2019, 22:23
by NN7D
Mike,
Sending spots - Log4OM does not send the mode. Its interrupted from the frequency (band plan) when Log4OM cluster receives the spot. Your notes define the mode - ie FT8.
V2 getting closer...
Doug - W7DRM
Posted: 20 Jul 2019, 06:53
You should also be aware that no cluster provider sends the mode as a field only the occasional mode added to the notes field by a spotter.
The mode is selected by your regional band plan which you can freely modify.
I must warn you that you will chase your tail because these FT8 spots do not conform to any IARU format for frequency, just an arbitrary frequency originally suggested by Joe Taylor, but even then the users do not stick to that they use whatever frequency they like - Its total mayhem.
We will only provide default bandplans that conform to IARU and local authority recommendations but we provide the user with an opportunity to create his own user bandplan which fits his personal requirements. These user bandplans do not get overwritten by Log4OM updates so the info is preserved.
See the many posts on this forum about user bandplans e.g. bandplan_r2_user.xml
