No idea it´s possible or not but .....
would be nice to have a userdefined black list for the cluster. The reason is that guys like F8DGY do spot only it´s own frequencies. If you go to look for a spotted DX ther is no DX. A "filter" like this possible
73´s ....
Cluster: Callsign blocking.
Re: Cluster: Callsign blocking.
uhm... i never considered this opportunity, to be honest
probably yes, but who will manage this blacklist?
Hi Daniele,
the User himself has to manage those "Blacklist". Some guys need spots like F8DGY sent others not. So it only needs a textfile or something like this and the user can write the calls in it.
mmmh seems that we should provide this file already filled with the well known "nino" callsign
If you use ve7cc sw this functionality has been already included (with many others filtering options )
http://www.ve7cc.net/#Reject
73 de Don IK2EGL
I use the integrated cluster modules in L4O and not need a separate browser to use the filteroptions of a ve7cc cluster. Should be possible to connect to ve7cc via the L4O cluster module but to use the different filters i have to send some commands in each of the different sessions. Would be easier to have a blocklist in the L4O cluster module. Each user can enter the spotter callsigns he would like to block in a seperate file.
@ Nino
As first call in the list F8DGY was o.K. Think "Nino" does not spotting the contacts of it´s own QRG and use the cluster as a "Logbook" or a "Chatroom"
@ Nino
