Idea for Locator (Grid) seconded.
Would also like to see, in addition to "worked/confirmed/LOTW" etc etc etc a "This Year" in the statistics so you knows if you have worked a DXCC/GRID etc in the CURRENT year, to show up in statistics or Cluster spot needs etc.
So, for example, in the statistics, if one selects "This year" instead of QSL status, one would have the countries in green if worked this year, yellow if worked before but not this year, and red for never worked.
Is this do-able?
In my case, I have to fudge this by using "Confirmed" as having worked it this year in another database but it is a real pain to do!!
Thanks!
"Current Year" in statistics/cluster spots
Re: "Current Year" in statistics/cluster spots
I can add a filter for date. Working on colors will be more complex because i have many functions that should be changed (and different colors for different options can be really confusing for users)
Yes, I guess that would be the easiest way, to show country/grid/etc stats between two specified dates.
THat would be really handy
