Would it be possible to add an extra field containing the remote ip adress in case a service is running on another pc/server.
eg. pstrotorcontrol.
Now you can select theTCP/UDP port, but also provide the external ip@ or 127.0.0.1 if the connection is local.
de ON3VNA
set external ip address for connecting to external services
Re: set external ip address for connecting to external servi
Yes, it should be possible.I'll check for that, I don't remember if there is something for that in the communicator code. I'll check as soon as I come back home.
