Omnirig with Icom 7300
Here we will provide support for developers working on integration
Re: Omnirig with Icom 7300
Post by G4POP » 09 Dec 2018, 23:10
In wsjt select OMNIRIG as the radio
W2MJP
Post by W2MJP » 09 Dec 2018, 23:54
G4POP wrote:
09 Dec 2018, 23:10
I selected omnirig in settings of wsjt, but this did not help. I had to switch back to Ic 7300. Now the CAT is working with Log4OM, That's Great, But now I can not use WSJT. :? It seems I can not run both Log4Om and Wsjt at same time I have to open wsjt first and when I close wsjt than log4om will go to CAT mode and operate. Log4om will not recognize CAT when WSJT is up and running.
Mike-W2MJP
Post by G4POP » 10 Dec 2018, 08:56
You CANNOT share a com port between two programs - So running WSJT using com ???? while Log4OM is running the same Com ???? or visa versa will not work
Omnirig allows what is called Multithreading which allows up to 8 programs to communicate with a radio simultaneously, providing all software that is using it is set to 'Run as an administrator' when its installed
If Omnirig is installed correctly then all software should select Omnirig (Rig 1 or Rig 2 whichever is connected).
The only place the radio, in your case a IC7300, should be selected is in OMNIRIG
I suspect that your issue from the start has been com port conflicts by attempting to use a mix or Omnirig and direct com port connection using WSJT etc
Try to find a local ham that fully understands how com ports work to help you.
W2MJP
Post by W2MJP » 10 Dec 2018, 11:37
Ok Terry
Thank you for your help.
Mike-W2MJP
W7DRM
Post by W7DRM » 20 Dec 2018, 21:49
Mike,
Did you resolve this issue? If not, let me know and I can try to assist.
Doug - W7DRM
