LoTW and Eqsl download procedure
Moderator: EI7JZ
4x1zq
Post by 4x1zq » 03 Aug 2017, 11:05
Is it possible to download LoTW and EQSL status for all my profiles at one task instead of log in and out from the program for a different profile at a time ?
73 de Avishay
4x1zq
Re: LoTW and Eqsl download procedure
Post by G4POP » 06 Aug 2017, 15:49
Not if the different profiles use different LOTW and eQSL user names and passwords of separate logbook databases
4x1zq
Post by 4x1zq » 08 Aug 2017, 08:39
I have an old callsign and a new (upgraded) one.
They are both linked to one database on LoTW Eqsl and Clublog.
In this way I can get awards regarding to one list which contains both callsigns.
In Log4OM I have 2 profiles, one for each callsign, but they point to one database file.
I can distinguish the QSOs by the operator field.
When I want to update my QSLs status by the download procedure from LoTW and Eqsl I have to do it separately for each profile and it is very awkward as it requires to log out the program.
Post by IW3HMH » 10 Aug 2017, 15:35
You can install (in a folder) a portable version, kept on the callsign that you use less. Unfortunately it's a very rare situation, pretty peculiar and potentially prone to issues.
Log4OM automatically upload QSO to eQSL, with 2 profiles will be difficult to decide what user/password/home parameter should be sent to the external system
