RRA - Russian Robinson Award
Moderator: OE6CLD
OE6CLD
Post by OE6CLD » 02 Sep 2014, 14:53
Hi all,
Please find attached the award definition for the RRA- Russian Robinson award. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_RRA.xml) into the <user>/AppData/Roaming/LogOM/awards folder (or in the confog/awards folder if you're using the portable version) and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://www.rdxc.org/RRC/AWARDS/rra_e.htm
Claus, EI7JZ/OE6CLD
award_RRA.xml
RRA- Russian Robinson Award
(302.97 KiB) Downloaded 148 times
Claus, EI7JZ/OE6CLD/DJ0DX
