Make FRENCH_DEPARTMENTS more user-friendly
Moderator: OE6CLD
HB9BRJ
Re: Make FRENCH_DEPARTMENTS more user-friendly
Post by HB9BRJ »
Hi Greg,
You are right with the 2 errors mentioned. As far as I know you should not correct them locally.
Claus, EI7JZ/OE6CLD is the Log4OM award expert. I'm sure he will apply the 2 corrections after having seen your post.
73, Markus
Yes, from award management page, while our award manager fix it for the mainstream
F4BPO
Post by F4BPO »
Have corrected with Award Manager thanks Daniele
73 de XV9Q Greg
OE6CLD
Post by OE6CLD »
Hi Greg,
I have uploaded an updated version of DDFM (Diplôme des Départements Français de la Métropole) where I have corrected both dept 06 and dept 28 (which had also the entry 29). Sorry, this was my fault (and my typos).
Please update your awards to get the new file(s).
The FRENCH_DEPARTMENTS is a generic award that was created at the very beginning when awards were introduced into Log4OM. It does not match any awards issues by REF or someone else.
Please continue to use DDFM.
Claus, EI7JZ/OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
