Award goals
Moderator: OE6CLD
yt9tp
Award goals
Post by yt9tp » 03 Jun 2014, 14:08
Some awards have several levels (i.e. bronze, silver, gold) which are accounted for number of points scored.
Are there plans to add support for goals in award definitions, so that Log4OM can alert user when he approaches or reaches one of the goals?
OE6CLD
Re: Award goals
Post by OE6CLD » 03 Jun 2014, 16:08
Hi Pedja,
I don't know if this will be possible. For this the award definition needs to have the various level thresholds and Log4OM needs to do all the calculations. Additionally, we would need some tracking like for the DXCC awards (contacts already submitted/validated) to be able to track what has been submitted for a previous level.
The current version of Log4OM allows everyone to mark specific QSOs for one or more awards. "Statistics and Awards" will allow you to view all contacts for a specific award (by default worked only), you also can select if for worked or confirmed contacts only. For most awards this will be fine, otherwise you can export the contacts into a CSV file (it will include the QSL status as well) and continue in Excel.
Claus, EI7JZ/OE6CLD
Claus, EI7JZ/OE6CLD/DJ0DX
