DME - Diploma Municipios de España
Posted: 05 Aug 2014, 15:00
Hi all,
Please find attached the award definition for the DME - Diploma Municipios de España award. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_DME.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://diplomas.ure.es/diplomas/dme/bases/
Claus, EI7JZ/OE6CLD
Claus, EI7JZ/OE6CLD
