I have created the new MySQL Database, log looks OK:
2020-01-15 18:05:50.8834 INFO: [DbMysql] : MYSQL deploying database log4omnext START
2020-01-15 18:05:50.8944 INFO: [DbMysql] : Connection string: Server=127.0.0.1;Port=3308;User ID=hb9cat;Password=teresina;Pooling=false;SslMode=None
2020-01-15 18:05:50.9124 INFO: [DbMysql] : Script loaded
2020-01-15 18:05:50.9354 INFO: [DbMysql] : MySQL creation file is saved here: C:\Users\marco\AppData\Roaming\Log4OM2\log\createDatabase_log4omnext.sql
2020-01-15 18:05:50.9474 INFO: [DbMysql] : Opening connection...
2020-01-15 18:05:50.9694 INFO: [DbMysql] : Running script...
2020-01-15 18:05:51.4844 INFO: [DbMysql] : MYSQL database CREATED SUCCESSFULLY (43)
2020-01-15 18:06:03.7636 INFO: [DatabaseManagement] : Connection Valid
2020-01-15 18:06:08.3517 INFO: [DatabaseManagement] : Connection Valid
Problem: trying to import an ADIF file I get a "Not connected to a valid database" error
The 2 last log rows above are the feedback from:
- Check Connection
- Switch to MySQL
My feeling: the "Switch to MySQL" is just doing the same as the "Check Connection" button; in Version 1 it took quite some processing and resulted on "Connected"
Marco HB9CAT
Create and use MYSQL Database
Re: Create and use MYSQL Database
when you switch you should see the connection parameters in the bottom right area of the main USER INTERFACE.
What did you see there? Did you saved configuration at the end of the process? switch is applied on SETTINGS SAVE
You're right, I didn't save the configuration correctly; I guess I just did save & exit
Now I see 127.0.0.1:3306 bottom right with a green dot, and the ADIF Import is working.
Thanks !
Marco
Thanks !
Marco
