Not uploading QSO's
Not uploading QSO's
Ver2 not uploading QSO's to QRZ and HRDlog even though the log automatic box is checked. The info is copied and pasted from Ver1. Ideas anyone.
Re: Not uploading QSO's
I have the samd problem for qrz it is normal for me because i am not suscribe
But hrdlog not upload and my login and upload code are ok and case are checked. It seems to be a problem because the online hrdlog not appear too.
Cedric
F4GWM
Cedric
F4GWM
F4GWM
CEDRIC
CEDRIC
I have the same problem for eqsl,clublog and hrd.
Manualy upload works but automatic upload does not.
The program scheduler times settings set to default
hi
here manually and automatic dont work on hrdlog i can see on my page that the logbook is updated with log4omv2 but nothing is change on the logbook
and the online logo doesnt appear too
F4GWM
CEDRIC
CEDRIC
I've contacted Claudio, owner of HRDLog.net for those issues including online status check. He's checking on their side
I found my mistake. I called a QSO which was not uploaded (QSO Edit)
and saw under the "My Qth" settings for the QSO that the input field "Station Call" was empty.
When i inserted my call here and QSO saved again, the upload went now
Automatic upload working fine here and only thing not showing is 'On Air' status.
73 Chris M0RSF
73 Chris M0RSF
G/QRP #07737 - Fists #15922
I checked EVERY confirmation upload this morning (Bulk, Manual and Auto) and every one works 100% so if you have an issue you did something wrong!
Password, user name, Key number, API code, Nickname or your QRZ subscription is expired or perhaps your not a paid XML QRZ user - Something is incorrect somewhere!
i have take the same login and upload code from log4om v1 and i put it in the v2 but nothing appear on hrdlog
i see information on hrdlog page say that the logbook is upload but nothing really appear on the hrd logbook
i think something is wrong because all parameter are same in v1 and v2
F4GWM
CEDRIC
CEDRIC
The information is a direct copy from version 1 which is working doing automatic uploads to both QRZ and HRDlog. I am a paid QRZ subscriber so that is not the problem.
