I am new to Log4OM, I did not have V1. I have a clean V2 install. No previous database.
I am in grid square CN85. I set my station configuration to ITU=6, CQ=3, DXCC=291
I think the program is miscalculating my CQ region as 5. I reset the QSOs I enter to 3, but then when I open the edit window they are reset to 5.
Also, when I open the edit QSO window, the program appears to clear the "Band" setting I made originally.
Attaching images of what I am seeing.
Greg - KJ7EHA
Edit QSO changes fields
- station-config.jpg (100.47 KiB) Viewed 3058 times
- QSObeforeedit.jpg (95.09 KiB) Viewed 3058 times
- EditQSOwithfieldschanged.jpg (73.37 KiB) Viewed 3058 times
Re: Edit QSO changes fields
Hi Greg,
Are you mistaking the CQ zone as yours zone? The CQ zone in the QSO record is the CQ zone of the station you have contacted... There is another field in the QSO record which is My CQ Zone. If you add that field to the QSO record display, you should see that they are all still set to CQ Zone 3.
Doug
W7DRM
Doug
W7DRM
The QSO was in WA state. Am I correct that WA is in CQ zone 3?
I manually set the CQ zone to 3 when I created the QSO because it came up as 5 by default. I thought CQ zone 5 was on the Eastern US. After adding fields to the QSO I saved it.
When I double click on the QSO to edit it, the CQ zone is reset to 5 automatically, and the Band Field is cleared.
Then when I save the QSO the fields I did not change are changed upon save.
- QSOafteredit.jpg (91.88 KiB) Viewed 3035 times
- EditQSOchangedfieldshighlighted.jpg (76.19 KiB) Viewed 3035 times
Change frequency from 146 to 146000 and 520 Hz so the frequency must be in kHz and Hz but 146 is in MHz.
If you do so the band will be show´n as 2m.
Easiest way is when your radio can be controlled by CAT via Omnirig. Log4OM will grab the correct frequency automaticly.
Greg, ok, now I understand. I have replicated the issue. You found a bug. We will get that fixed quickly! Thanks for reporting.KJ7EHA wrote: ↑21 Jan 2020, 16:16 The QSO was in WA state. Am I correct that WA is in CQ zone 3?
Doug
W7DRM
Doug,
I've been on V1 for about 4 years and converted to V2 3 days ago. I've logged 17 QSO's so far in V2 and noticed about a third of those QSO's did not have an operator name or address information although they did have correct ITU and CQ zones. These QSO's were logged from JTAlert/WSJT-X and I'm using hamqth.com for lookups. I went in to edit those QSO's and upon clicking "refresh data" I saw the ITU or CQ zone changing to something incorrect, like Greg is experiencing. You have been able to verify this behavior which is great.
When a fix comes out for this, will there be a method to fix or identify the QSO's that have incorrect data? Depending on how long that takes, it could be quite a chore to find and fix these records.
With respect to the no name and address, I'm not reporting that, just explaining why I was in Edit QSO and updating information. I'll continue to watch that to figure out if there is an issue.
V2 is pretty slick, thanks to all.
73 - Tom NS8K
