So have an issue with using the cluster and local spots on port 7300.
First of all I have a Flex 6600. I am using Slicemaster as the bridge between the Flex and CWskimmer and WSJT. Works great.
I often let Log4om monitor a couple bands of CWskimmer looking for new ones. I did this with V1.
I just realized that it does not work unless Log4OM starts the telnet after everything else has started. This does not work very well because if I stop copying CW and then restart again Log4OM is not getting local spots. So I have to stop telnet in Log4OM and restart it. Same with WSJT. Its nice to see Ft8 stations in the Log4om cluster against my log looking for new ones.
Can anything be done where Log4OM can restart the telnet connection? Isn't that was Heartbeat did in V1?
LocalHost
LocalHost
