I have been controlling the CAT by using a splitter using VSPE from Enterlogic. This has worked FB in providing the CAT function for WSJT-X and Log4omV1. IN V2, the splitter does not split. My Comm port will work either on WSJt-X or Log4om2. not both at the same time. I go back to V1 and it is working for both. I have only 1 comm port on my computer. If there is no solution on Log4om, is there another way to obtain a second virtual comm port?
Art K0ay
V2 lost CAT control
Re: V2 lost CAT control
Hi Art,
you are reffering to V2 so i moved this to the V2 section of the forum. Please for V2 issues/questions
only use the V2 part of the forum ....
Hi Art,
Why don't you set up WSJTx and Log4OM V2 as suggested in the User's Guide using OmniRig? It handles both very well.
Doug - W7DRM
Doug - W7DRM
