Hello.
I'm having a problem with EQSL auto-sending.
With LOG4OMV1, when I was entering local qso's, and I didn't want to systematically send the confirmation to EQSL, I unchecked the box and it worked.
With LOG4OMV2, I proceed the same way, I go to settings/program configuration/external services, and I uncheck in the EQSL tab, the box "automatic upload on new qso". Then, once the local contacts are entered, I will check the box again. Despite this manipulation, the confirmations still go to EQSL.
Did I do something wrong?
73 to all and happy Sunday.
Re: I'm having a problem with EQSL auto-sending.
Did you click 'Save and Apply'
Just clicking save will not apply the changes until the next program restart
- Advanced Class
Hello Terry.
OK I will try to click only on "SAVE".
Thank you.
Thank you.
What Terry means is that if you click on "Save and apply" it will be work without a restart.
If you hit "Save config" the changes are active after a restart of Log4OM ...
- Advanced Class
Many thanks Juergen
