Cluster "Reliability" does not match Prop
Should the "reliability" value presented in the cluster view approximate the reliability calculated in the propagation view? (F9 - Circuit Reliability graph) Mine does not. Right now V31 to here shows 85% in the cluster window and 0%, just starting to ramp up in the next hour. If the column is not useful, I'll just move it out of view, but was hoping this would be useful information. Is it possible the UTC offset is not being done correctly for one of them?
73, Duane AC5AA
Re: Cluster "Reliability" does not match Prop
Already a thread going here.
https://forum.log4om.com/viewtopic.php?f=32&t=4814
PS: you dont have to move column out of view. You can turn them on and off
