In an effort to change the columns and spacing I ran some items out of sight. I looked on page 22 in the user manual to see if there is a default setting to bring everything back to the original state. I guess I should leave well enough alone.
Thanks for any help.
Andy... W3LI
Managing Layouts
Re: Managing Layouts
Right click on column header, select edit
Click the deselect items button then click the select all, that will restore all columns
OK Terry,
When I right clk on the column header a box comes up with EDIT TABLE LAYOUT and RESET TABLE LAYOUT plus some other things. I do not see just EDIT. I do not get the deselect items button or see the select all button.
Sorry,
Andy
Sorry,
Andy
I did that as well as Edit table layout, nothing happens.
Andy
Andy
the two buttons I referred to are in the edit table layout window at the top
RRR Terry, Got it. TU
BTW, I am playing your vids on my laptop and performing the same operations on the my PC. Back up with the Quick Start Guide and the User Guide. Hope I get it all together and operating.
Later, Andy...W3LI
Later, Andy...W3LI
Andy,
Excellent and be sure to (very often) download the User Guide. Terry is always making changes to add and clarify things.
To get the latest User Guide: Help / User Guide / English (force update)
A new/updated User Guide will be downloaded and automatically open in your preferred PDF reader. Then save that to your local hard-drive. But be prepared to write over that initial UG with the new/updated version..
Tnx for using V2.
