Is it possible to force an upload to ClubLog? I have just amalgamated two databases successfully, but one was not uploading to Club Log, so now I have some data missing from my new consolidated ClubLog database.
73, Richard, G3ZIY
Clublog
Re: Clublog
Hi Rich,
activate the databases one after the other. If one is active open QSL manager and let check for
Clublog sent = No. Now you can select all entries and use the upload button.
Re: Clublog
Richard,RichardCSD wrote: ↑11 Mar 2020, 16:35 Is it possible to force an upload to ClubLog? I have just amalgamated two databases successfully, but one was not uploading to Club Log, so now I have some data missing from my new consolidated ClubLog database.
73, Richard, G3ZIY
Best to do a bulk upload from the QSL manager select Clublog and upload then at the top of the window there is a button, if I recall it's labelled special something, sorry to be vague but I am not at the pc.
It will purge the existing Clublog data and upload everything in your logbook database
Re: Clublog
Terry, I tried to do a bulk upload and got "Upload exception. Check log" message, and no change to my Clublog data on their webpage. I can't find the log to check, and it doesn't seem to be mentioned in the latest user guide.
I thought maybe the exception was due to wrong credentials in the settings/program configuration/external services, but they check out ok. More help needed please.
Re: Clublog
Access to the log file is in the help menu - Show LogRichardCSD wrote: ↑14 Mar 2020, 10:32 Terry, I tried to do a bulk upload and got "Upload exception. Check log" message, and no change to my Clublog data on their webpage. I can't find the log to check, and it doesn't seem to be mentioned in the latest user guide.
or you can watch the log entries in real time by using Help/Realtime log
If you want finer detail you can select trace mode in Help/Log Level
Are you sure that you have set your clublog parameters correctly in the Settings/Program Configuration/external services/clublog tab
