POSTING MY WAS AWARD ON LOG40M
AH6TX
Post by AH6TX »
I recently received my WAS award certificate from ARRL. How do I add it into LOG40M?
Howard
AH6TX
gvm920@gmail.com
818-203-5337
Re: POSTING MY WAS AWARD ON LOG40M
Howard,
Have you looked at WAS in the Award Statistics window?
Have you download (detail download) from LOTW with your validated Q's?
AH6TX
Post by AH6TX »
Yes. I did. I received my WAS certificate #63301. I just want to have it show up on my LOG4OM software.
AH6TX wrote: 25 Mar 2020, 05:41 Yes. I did. I received my WAS certificate #63301. I just want to have it show up on my LOG4OM software.
Where and how would you want it to 'Show up'
AH6TX
Post by AH6TX »
I believe I should show up under f3 so that when someone else pulls me up as a contact they can see my awards. If you have other suggestions I would like to see/hear them.
Howard
AH6TX wrote: 25 Mar 2020, 20:04 I believe I should show up under f3 so that when someone else pulls me up as a contact they can see my awards. If you have other suggestions I would like to see/hear them.
Howard
Why not post it as your photo on QRZ then anyone looking you up in Log4om will see the award
AH6TX
Post by AH6TX »
I understand. If that be the case what is the purpose of the database field/column for?
Howard
ah6atx
AH6TX wrote: 26 Mar 2020, 20:27 I understand. If that be the case what is the purpose of the database field/column for?
Howard
ah6atx
Which data base field column are you referring to?
