HRDLog On AIR status
F4WBL
Post by F4WBL »
I have log4om V2 2.4.0
i have check the box "automatic HRDlon on Air " but I can't see my status "On AIR" HRDLOG.NET
working with log4om V1 !?
keep up the good work
F4WBL
Re: HRDLog On AIR status
Hello OM,
not know what´s wrong at your side but here all is working fine. You need
to open Logbook site at HRDlog.net to see the On Air status ....
CT1BXX
Post by CT1BXX »
Hello Emmanuel,
Just one thought is CAT working well?
Have you checked "Automatic HRDLog ON AIR?
Sorry :oops: to be addressing such elementary questions that you’ve certainly checked, but just in case you’ve forgotten something
Here it works perfectly.
73 Manuel Fernando CT1BXX
Hi Manuel,
he wrote in first post that the Box is checked but as you say, it could only be an elementary
thing like wrong login data or not connected to CAT. I´ve checked without a CAT connection
and On Air will not be show´n then. That make sense so for On Air a frequency is a must have.
F4WBL
Post by F4WBL »
on air box checked has mentioned in my first msg
all contacts are going to HRDlog automatique ly = all good
but my friends don't see me ONLINE
I don't have CAT ( TX not connected to the computer)
but if I use the V1 version = they can see me ON AIR and the frequency
but not if I use the V2 version = NOT on air
F4WBL wrote: 27 Mar 2020, 14:39
Is CAT connected in version 1?
F4WBL
Post by F4WBL »
Hi Terry
nope CAT not connected in version 1, but ON AIR Works
why is it not the same on V2 ?
Strange
F4WBL
Post by F4WBL »
Ok guys
you were right
to be ON AIR on HRDLOG the CAT needs to be ON (even without a TX connected)
then from Cluster
- 1 click to load
- double click to load into jhe CAT so it then shows the right Frequency
Regards
Emmanuel
F4WBL
Post by F4WBL »
Well
it worked onetime...
impossible to make it work again
DAM!
Seems the issue was the HRDLog server because its working OK today, perhaps overloaded by WPX contest at the weekend
