Lost all settings!
Re: Lost all settings!
No ignore those check boxes otherwise all Log4OM dedicated information will NOT be included
Just like this
I have been using Ver 1.32.0. Today it wouldn't startup all the way such as not showing on the screen but in Task Manager shows to be running. I restarted my computer a couple of times but did not make the program viewable. Without viewing any documents or videos I installed the latest version Log4OM2, 2.6.1.0.
And now my previous QSO's are not there. Did I lose them? Or are they still somewhere in my older Log4OM files?
You should install VERSION 1.41 first, that should restore your original version 1 setup
Having got V1 running properly export an ADIF as ADIF version 3
Then follow the instructions for installing and setting up version 2 as detailed repeatedly here on the forum, on Facebook, in the user guide, quick start guide and YouTube tutorials
Hi, I can run together V1 and V2?
I need for read and apply the setting info..
73s, Camillo
Yes you can
You can also have V2 send and QSO's you log to the V1 logbook, see user guide for information
Hello Terry,
can I use the older backup folder (synchronized with Dropbox) for my new V2 backup ?
73s, Camillo
Yes but I would make a new folder on Dropbox to save confusion
