GM
after some hours and days to try how run both log4om v2 and fldigi i found by hazard on the net the bridge "fldigilabs gateway " http://www.n2amg.com/software/fldigi-dxlabs-gateway/ which run very well.
After qso only click on "save qso" and log4om registred qso on the log.
1/ run fldigilabs gateway (enter path of fldigi"), logging via dde 127.0.0.1, click commander
2/ you must install commander "dxlab suite" et run commander on port com 8
3/open log4om v2
3/ send cq in test ie , no problem , tx run(ouf !)
4/after qso, only you click "save qso" and qso is registered in the log.
hope soluce help you. Fldigi has some modes very cool like olivia and hell.
73 Eric
fldigi + log4om v2, prob fix (icom 7600) !
Re: fldigi + log4om v2, prob fix (icom 7600) !
You must speak to FLDigi, DXLabs or the gateway developer for this issue it is nothing to do with Log4OM
probably Terry except that since version 2 I had not been able to traffic in olivia for example, the tx did not work. I was not the only one to say so. I didn't want to split the ports. It's a solution that works.
73 Eric
73 Eric
