Friends,
Thanks for this amazing software. I was using it great till i updated to V2.7.0.0
My Configuration: Windows 7, Radio IC 7610,JTDX v2.1.0-rc149. Logging directly via UDP to log4omv2. All was perfect till i updated to release 2.7.0.0 of Log4omV2, after which i noticed that my automatic upload to LotW was not happening. I found the cause to be the default in CONFIRMATIONS SENT status of LotW in digital modes being Sent : No, I had set it up to be as : requested, and chose it as the default upload Flag in EXTERNAL Services. After the update , the default confirmations is reverting to NO, event after i changed it to requested.. Further i noticed that, this is happening only for digital QSOs, when i do phone or CW, the Confirmations default is: requested , and the LotW autoupload happens on closing the program.
So i narrowed down the issue to be on digital alone , via UDP logging from JTDX. Prior to the update to 2.07.0.0 , it was working great.
I hope i have conveyed the error to the experts.
What am i doing wrong ? Please advise
Thanks , 73 , Jith VU2OY
Logging from JTDx to Log4OM2 Error
Re: Logging from JTDx to Log4OM2 Error
I believe there are other posts about this in this forum but from memory there is a setting in JTDX causing your issue
Thanks Terry\
Any pointers
A quick search did not yield a solution
TIA
Jith VU2OY
Any pointers
TIA
Jith VU2OY
In JTalert check for a setting sent status requested
Jith,
You noted using JTDX, but did not advise if you are also (or not) using JTAlert.
If you are using JTAlert there is a page of settings that impacts QSOs being sent into Log4OM V2.
I've attached screen-clip of tic boxes that you do NOT need to check if using JTAlert.
- 5_JTA-Logging.JPG (143.12 KiB) Viewed 2598 times
Hello Nolan
No , i do not use JT Alert
Jith,
Just did some further checking and noted this issue has been addressed and will be in the next version release.
Thanks Nolan
Great Going
Shall look forward to it
Thanks 73
Jith VU2OY
Great Going
Thanks 73
Jith VU2OY
Thanks Terry , Nolan and team ,
The Logging issue with JTDX which i reported earlier has been solved with the newest release.
Kudos
Jith VU2OY
Kudos
Jith VU2OY
