Why does the Short Path (SP) column in the Cluster List always report 313 as the bearing for all US stations. The correct bearing is reported for all stations outside of the US. Did I miss a setting somewhere ?
Thanks, Steve KH6CT
Short Path in Cluster List
Re: Short Path in Cluster List
Cluster path is just taken from the country file which indicates the approximate centre of the country as a rough guide.
Once you click a spot and the call is entered into the call sign field a full lookup is done and provides an accurate sp/lp at the top of the screen
