Hi All,
Is there a special reason why the red text 'Refreshing...' no longer appears at the bottom of the 'Qsl Manager' window during the refresh?
In the previous version it was present and I found it very useful.
73 Dick DL1CLM
Refreshing Qsl Manager window
Optibeam OB 9-5
Optibeam OB 9-5
Re: Refreshing Qsl Manager window
Dick,
Short of a visual indicator that 'something' is processing I'm not sure what else it can do.
My cursor chanages to an hour-glass during the refresh. That appears to occur for the same time span that a visual banner would have.
Can you provide more points for having the visual indicator reprogrammed?
It may or may not be easy in light of the interaction inside V2 programming, but data points will help provide a good basis.
Nolan,
I don't know exactly what you mean.
In version 2.7.0.0 this Refresh indication was still present and after the change in the 'Qsl Manager' form, where the function 'QSO Map' has been added, it has disappeared.
In 'QSO Manager' it is still present, just like in the 'Recent QSO's' Tab.
73 DIck
73 DIck
Optibeam OB 9-5
Optibeam OB 9-5
The 'Refresh' message was removed in that view when we stopped automatically refreshing the list and added the Search button.
We changed this because users requested it as a way to speed up the selection of confirmation type
Thank you Terry, for the explanation.
Optibeam OB 9-5
Optibeam OB 9-5
