I'm still translating Log4OM into French ...
I'm moving slowly in fact I'm trying to translate function by function...
I plan to tackle the translation of the function to print labels
as I have already described it below I have some big problems using this function to the point that I proposed to review this function and I proposed another approach
I have no news on this proposal (and this is to be expected) but before I go into a translation, please tell me if you plan to review this feature or not ?
because if this function is planned to be modified, I will wait for this new version
otherwise I will need some help to make my home work properly
thank you in advance if you want to keep me informed
Label printing issue
Re: Label printing issue
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
OK Terry
I’m waiting...
I’m waiting...
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Hello all
I have tried with labels that are 70mm width, by 35mm height.
Margin top and bottom 5mm - Margin left and right 0mm - Page 21x29,7 (A4), 3 columns, 8 rows.
The result is a catastrophy....
Does not work in both directions : labels end up being wrong sized in height and width.
How to understand the corrective factors ?
What is a proportional vertical corrective factor ?
What is a proportional horizontal corrective factor ?
What is an inverted vertical corrective factor ?
What is an inverted horizontal corrective factor ?
Thanks + 73
Paul F6EXV
Paul F6EXV
I just tested again
indeed we can see that there has been progress but it is still unusable for me
We manage for example to make correctly (more or less) the definitions in "Label definition" but when we go to "Label print" everything is shifted
moreover, the size of the "Label Print" window cannot be modified.
I maintain that it is unusable in state ...
Wait & See
I just tested again
Wait & See
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Please ensure that you printer software is NOT set to "fit to page"F6FLU wrote: ↑24 Dec 2020, 14:18 Hello
I just tested again
Wait & See
Hello Terry
no I don't use this function...
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Yes I did
If you want I can send to you the pdf page from the label definition and the pdf page with some real QSOs
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
What label print stationary are you trying to print
Make
Ref No
Labels per sheet
Number of columns/rows
Label size
Margin and spacings
Printer make and model
