max qso number?
g0osk
max qso number?
Post by g0osk »
Hi
I`m sure this is just me not being savvy with the software,but i dont seem to be able to increase the max number of qso`s?
I am currently on 9768 and wonder what will happen when i reach 10000
Do i need to start a new logbook (SQLite) or will it just mean that i will not be able to see all my contacts on one screen
many thanks
Colin
G0osk
Re: max qso number?
There is no maximum, I have one test logbook with 98000 QSO's and the single SQLite database is good for up to about 125K depending on the PC power. The max number you refer to is the maximum displayed and you can change that.
Generally if you go over 100K QSO's you should change to Mysql database
My own log contains 16789 QSO's at this time
Re: max qso number?
26031 here in the SQlite Database ... All working fine.
NN7D
Re: max qso number?
Post by NN7D »
Colin,
The Max QSO setting affects how many contact records are displayed. You can set this to 0 to see all records. Or set it to a lower number for performance.
Doug
NN7D
