Previously used LOG4OM2 with FTdx1200 and FT1000MP TRX without problems via Omni-rig. Now replaced the FTdx1200 for a FTdx101D and can't get the CAT working.
The FTdx101D CAT works fine with WSJT-X and N1MM. Also the HRD CAT works fine with the FTdx101D. As judgested, I downloaded the latest ini files for Omni-Rig. Configuration in Omni-Rig(1):
Rig Type - FTDX101D
Port - COM11 (which is the enhanced port)
Baud rate - 38400
Data bits - 8
Parity - None
Stop bits - 2
RTS - Low
DTR - Low
Poll int. ms - 100
Timeout. ms - 4000
The FT1000MP is configurate as Rig(2). When switch in LOG4OM to TRX 2, the CAT for the FT1000MP works fine but no CAT for TRX1.
Any suggestions?
73, Nico PA3ADU
CAT connection FTdx101D
Re: CAT connection FTdx101D
Figured out the problem finally. Set the RTS to "LOW" and in the FTdx101D menu to "OFF".
For some reason, Omni-Rid is sensitive to this while the order programs will work with RTS "On"
Hello Nico,
thank´s for "input". Will move this post to the correct Log4OM V2 part of the forum
that it can be found by the V2 users.
