I have been logging contacts, and have found that I used the wrong call sign
I can go and edit the contacts to correct my call sign but I have +_ 4000, the country is correct
but the callsign is incorrect, is there a way that I can change them all at once
Correcting incorrect call sign
Re: Correcting incorrect call sign
Hello OM,
yes there is a way you can do via the QSO Manager. Please check the manual for Bulk editing or check
Terry´s Youtube Tutorials for that. Not at home at the moment so i can´t check this out.
Will try THANKS
It worked! Thanks once again
