eMail alert 1
WB8ASI
Re: eMail alert 1
Post by WB8ASI »
Dan, I have the same problem. The Test email works just fine. The Alerts work fine, but does not trigger an email. I've checked my settings and everything looks good. I interested in what you find. Thanks, 73, Herb WB8ASI
F6FLU
Re: eMail alert 1
Post by F6FLU »
WB8ASI wrote: 13 Apr 2021, 19:48 Dan, I have the same problem. The Test email works just fine. The Alerts work fine, but does not trigger an email. I've checked my settings and everything looks good. I interested in what you find. Thanks, 73, Herb WB8ASI
Hello Herb
I think it is a problem of Log4OM
I tested different providers like numericable, orange, gmx, netcourrier, icloud
none works ...
Dan - F6FLU
https://F6FLU.org
WB8ASI
Re: eMail alert 1
Post by WB8ASI »
BonJour Dan, Also, my "enable destination" box is located just like your screenshots on the "E-mail settings" page.....NOT on the "Cluster Alert" page as shown on page 78 of the User Guide (latest revision). 73, Herb WB8ASI
Re: eMail alert 1
WB8ASI wrote: 13 Apr 2021, 20:22 BonJour Dan, Also, my "enable destination" box is located just like your screenshots on the "E-mail settings" page.....NOT on the "Cluster Alert" page as shown on page 78 of the User Guide (latest revision). 73, Herb WB8ASI
Herb,
FYI ... there is a new UG as of today. Terry uploaded an update. The e-mail information is still on Page 78.
Are you experiencing the same as Dan? You can get a "test" just fine, but you do not get any Alerts via e-mail?
As I recall Dan is getting Alerts OK in his Main UI ... is that the case for your installation as well?
I've just added your e-mail (from QRZ) to my Alert list and turned on my 'test' alert. You should start receiving e-mails with those alert messages.
Pls advise if that is the case. My e-mail is good at QRZ.
I've also sent you an e-mail direct.
F6FLU
Re: eMail alert 1
Post by F6FLU »
I just created an email account on outlook and I tested the alerts via outlook,
it still does not work, I am not receiving any email ...
Dan - F6FLU
https://F6FLU.org
Re: eMail alert 1
F6FLU wrote: 14 Apr 2021, 09:56 Hello
Dan,
Pls check your e-mail. I sent you a message within the past hour. I'm asking you to submit a Support Request. With that additional data we will have more information to work with to help resolve your issue and that of Herb's in Michigan.
F6FLU
Re: eMail alert 1
Post by F6FLU »
Yes Nolan
Trace file has been sent to Lele ...
Thanks again
Dan - F6FLU
https://F6FLU.org
F6FLU
[resolved] eMail alert 1
Post by F6FLU »
this issue is resolved with version #2.12.0.11
I want to thank you for all the work accomplished on the subject of alerts via email.
Many thanks to "Lele" for developing such a quick fix,
Thanks to Nolan for his perseverance and
Thanks to Terry who works a lot behind the scenes and does a wonderful job on the documentation...
Dan - F6FLU
https://F6FLU.org
