Re: Auto upload to HRDLOG.NET work intermittently. Have to force manually.
WB5UDI
Post by WB5UDI »
All of a sudden, my auto upload to HRDLOG.net isn't working correctly.
QSO logged in WSJT-X and then logs into LOG4OM.....but then sometimes it uploads to HRDLOG.net and sometimes it doesn't.
Here is the diagnostic page message I receive:
4/7/2021 11:42:44 PM [DbSqlite][SaveQso] : SQLITE SaveQSO exception while saving QSO with QsoId 20210407234235795
[EXCEPTION] constraint failed
UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode
Thanks for your assistance!
Sincerely,
Stan WB5UDI
This stated that the QSO is a duplicate so like already uploaded, is another program also uploading?
WB5UDI
Post by WB5UDI »
Thanks for that description!
Well, I upload to e-QSL also, but I've been doing that since using LOG4OM for years.....I wonder if I change the upload timing in the EXTERNAL SERVICES, or the PROGRAM SCHEDULER to be offset if that might help?
It is odd that it just began recently.....no changes to the computer or any other programs.
WB5UDI wrote: 08 Apr 2021, 10:50 Thanks for that description!
I was refering to external programs not Log4OM, like WSJT, JTDX, JTALert etc etc etc
No will not make any difference
WB5UDI
Post by WB5UDI »
Thanks, Terry...
No, not using JTAlert or any other program other than WSJT-X...
I have the port open, so LOG4OM is listening and populates when I call someone on WSJT-X.....but as soon as I accept the completed QSO box in WSJT-X, LOG4OM accepts it...
In the diagnostic box, I can see it doing an IMPORT ADIF, then attempts to upload the QSO to HRDLog.net, and eQSL..... that's when I see the conflict message.
Appreciate your help!
Thanks,
Stan
Check that WSJT is not also uploading to the on line logbook
WB5UDI
Post by WB5UDI »
Terry,
Unless I'm missing something, WSJT-X doesn't upload to anything other than PSKReporter.......when that box is checked.
Can you show me what setting could cause that?
Sincerely,
Stan
WB5UDI wrote: 08 Apr 2021, 12:12 Terry,
Sincerely,
Stan
I am not a WSJT expert it was a suggestion of a possibility, perhaps check there is nothing in the WSJT menu so such uploads
WB5UDI
Post by WB5UDI »
Terry,
Thanks, will do....
Really appreciate your real-time assistance.
LOVE LOG4OM!!
73's de Stan WB5UDI
Stan,
Double-check in Log4OM at: Configuration / Software integration / ADIF Functions
Make sure you do NOT have the "Enable ADIF monitor" box tic'd or enabled.
