Hi everybody,
I recently started using LoTW, when I have problems when I download qsl confirmations.
I will try to explain.
QSOs are recorded in Log4OM as USB and LSB, but when I sync with LoTW, that probably uses only SSB, those with qsl
get duplicated.
I literally have the same qso but the mode is set to SSB.
Also (but is not a relevant problem) I get a YES on normal QSL and not on LoTW qsl's column, but this can be easily fixed manually.
Last but not least, if I delete the SSB duplicated qso, whenever I try to download confirmations from LoTW,
the qso is created again.
Can someone help me to solve?
73 de Antonio.
Duplicate qsos after LoTW sync
Jump to
- News
- ↳ Country & Special Callsign file updates
- Log4OM v2
- ↳ FAQ
- ↳ General discussions
- ↳ User support
- ↳ Error reports
- ↳ Feature suggestions
- ↳ Country (LANGUAGE) Forum
- ↳ German language forum
- ↳ Spanish language forum
- ↳ Portuguese language forum
- ↳ French language forum
- ↳ Italian language forum
- ↳ Award Support
- Log4OM v1
- ↳ User Support
- ↳ Software Integration
- ↳ SDR & VSP
- ↳ Award support
- ↳ FAQ
- ↳ Error Reports
- ↳ Technical Information
- ↳ Send data to Log4OM
- ↳ Receive data from Log4OM
- ↳ Databases Etc.
