radio configuration is not saving
do1otw
Post by do1otw »
After updating from V2.15 to 2.16 the program is loosing the radio configuration i had configured in the hamlib window.
Atfer every restart of the programm and when i start the CAT interface, the radio starts with 145.000000 MHz, also in the Mode-Selection Menu
i cant choose a TX mode manually, the selected mode is switiching between this mode and another mode automaticly up and down.
Is there any solution to solve this problem ?
73 Timo, DO1OTW
Re: radio configuration is not saving
do1otw wrote: 17 Aug 2021, 17:38 After updating from V2.15 to 2.16 the program is loosing the radio configuration i had configured in the hamlib window.
73 Timo, DO1OTW
Timo,
This has been discussed/asked many times on several threads here on the Forum.
That being said it is a bug in L4OM as to handling Hamlib. It will be addressed when Danielle returns from holiday after (approximately) the 20th.
In the meantime use Omnirig as it is much more stable than Hamlib.
do1otw
Post by do1otw »
tnx for info !
73, Timo DO1OTW
