Would it be possible to include an installation select location option in the Log4 setup to enable the software to be pointed to a separate drive in order to have two totally separate installations? This as I see it is the only way at the moment to interface to 4 radios - 1 using TCI, the others on Omnirig.
Charlie GI4FUE
2 Instances Of V2 on Separate Drives
Re: 2 Instances Of V2 on Separate Drives
Charlie,
I dont see a problem with that if you use the portable version on the second drive then in Program config/user configuration set up a shortcut for the Portable installation (Chain icon on the right)
I currently run my testers version from the C drive and my personal logbook from my D drive, one uses Hamlib for the Flex and the other Omnirig for my Elecraft and Icom radios, the only conflict you might get would be if your trying to use UDP connections for both installs with WSJT
BTW my SunSDR 2 DX is on order
