Hello Danielle,
I have a problem: Log4OM 2.17.0 no longer recognizes my settings nor my log
When starting it it seems to be a new installation....
Is there a way to re-discover the configuration? I imagine that there is a file where all the data was stored? Mays I have its name?
On the other hand, Log4OM 1.34.0.0 seems to be working properly but with a very old log. Is there a way to use the configuration frame?
Thanks in advance.
73 QRO.
No more settings ?
Re: No more settings ?
As Terry wrote, check the rescue part in the french manual. If you don´t find it here is the direct link:
https://www.log4om.com/l4ong/usermanual ... NG_FRE.pdf
Other part of your question. No there is no way to use your V1 Setup for the V2 version. There are many
changes and the UI is completly different.
Thank you DF5WW and G4POP for your prompt answers.
Unfortunately, it doesn't work !
I've found the file, copy and paste it in the "AppData/Roaming/Log4OM2/user" directory, rename this file as written in the manual as config.json...
I've started Log4OM v2 but... it is empty, no settings !
My file is about 58 ko.
When I start Log4OMV2 it creates a last_valid_config.json file in user directory with the same size.
And it creates also a new config.json file (12 ko).
Any idea ?
Thanks in advance and good week-end.
Any idea ?
You will need to use an older config.json file because as you have found everytime you start Log4OM and close it it generates a new json file.
Try the file in the 'Historic' folder C:\Users\.........\AppData\Roaming\Log4OM2\backup\Historic
Done !!! Fantastic ! Thank you !!!!
